Betaflight modes issue
Hi! my name is Leo. I´ve been flying cinematic drones for 7 years and now im going into FPV! I just bought a Cinebot 30 from Geprc and I also bought a Radiomaster Pocket controller. Both ELRS 2.4
I have succesfully binded the air unit, the googles, and the controller. I can see the reaction on Betaflight when I move the sticks, which indicates that the quad is effectevely connected to the controller.
Nevertheless, when trying to configure the flying Modes (Angle, Horizon, Arm switch), If I press the arm switch on the controller, in betaflight it wont do anything. I have double checked but still cant find the issue. Also, when I see the CLI after inputing "status" it doesnt really show anything that I can identify and fix. I have tried to armed the quad even disconnected from betaflight but still wont work. The CLI is the following:
Entering CLI Mode, type 'exit' to return, or 'help'
# Building AutoComplete Cache ... Done!
# status
MCU F722 Clock=216MHz, Vref=3.27V, Core temp=53degC
Stack size: 2048, Stack address: 0x20010000
Configuration: CONFIGURED, size: 4034, max available: 16384
Devices detected: SPI:1, I2C:0
Gyros detected: gyro 1 locked dma
GYRO=ICM42688P, ACC=ICM42688P
OSD: MSP
System Uptime: 271 seconds, Current Time: 2023-12-16T00:41:32.750+00:00
CPU:61%, cycle time: 125, GYRO rate: 8000, RX rate: 243, System rate: 9
Voltage: 399 * 0.01V (1S battery - OK)
I2C Errors: 0
SD card: Not configured
Arming disable flags: CLI MSP ARMSWITCH
MSP ARMSWITCH
Obviously I am missing something, I would be very thankfull if any of you could give me some light! All the best
I'm going to make the assumption that you haven't assigned the switches to any channels in EdgeTX. You need to do that in the INPUTS and MIXES pages for the model on your RadioMaster Pocket otherwise Betaflight won't be receiving any data over-the-air from those switches.
Have a watch of DrainMan FPV's video below. It's demonstrated on a different transmitter, but the process of assigning switches to channels is exactly the same on the RadioMaster Pocket...
[-] The following 2 users Like SnowLeopardFPV's post:
  • leobrum, Eyes.fpv
Snow, I appreciate it man!
  BetaFlight Connection Issues..... Coleon 17 580 02-Apr-2024, 12:26 PM
Last Post: iFly4rotors
  Betaflight 4.4.3 on Speedybee F4V4 Ladu 4 216 14-Mar-2024, 04:45 PM
Last Post: Ladu
  VTX issue - ATOMRC hurricane 5 bar1 1 176 10-Mar-2024, 12:36 PM
Video Troubleshooting motor issue - I'm stuck, help! doraymon 7 303 25-Feb-2024, 05:48 PM
  issue in walksnail x Eyes.fpv 0 149 09-Feb-2024, 07:15 PM
Last Post: Eyes.fpv
