06-Apr-2023, 11:28 AM (This post was last modified: 10-Jun-2023, 04:18 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. )
EDIT (10th June 2023): Betaflight 4.4.2 is now available. See another thread HERE for details.
Betaflight maintenance release 4.4.1 was published a few hours ago. Details of the fixes since Betaflight 4.4.0 are below along with any relevant links.
One important fix to note in this release is to the AA filter for the ICM426XX gyros (issue #12444) that were causing some people who were running those gyros some significant issues.
Unfortunately it doesn't look like the GPS Rescue improvements (PR #12343) were included in this maintenance release because there is no mention of it in the release notes and that PR only appears to have been merged into the master branch, so it looks like we will have to wait for Betaflight 4.5 before we get those improvements, or use a nightly build of the master branch. EDIT: The GPS Rescue improvements did actually make it into this maintenance release after all, but under a different PR (#12413) which isn't listed anywhere in the official Betaflight 4.4.1 release notes. I have therefore now added an additional entry to the list below for that under the "Improvements" heading even though it's still not listed in the official release notes on GitHub.
IMPORTANT NOTE: User's of H7 FC's that utilises an SD Card for blackbox logging should be aware that a bug in Betaflight 4.4.1 prevents the FC from logging data to the SD Card. More details are in post #11 of this thread.
What's Changed
Improvements
- Betaflight 4.4.1 Firmware & Release Notes: https://github.com/betaflight/betaflight.../tag/4.4.1
- Betaflight Configurator 10.9.0: https://github.com/betaflight/betaflight...tag/10.9.0
- Betaflight TX LUA Scripts 1.7.0: https://github.com/betaflight/betaflight.../tag/1.7.0
- Blackbox Log Viewer 3.6.0: https://github.com/betaflight/blackbox-l.../tag/3.6.0
- Betaflight 4.4 Release Notes: https://betaflight.com/docs/release/Beta...ease-Notes
What's Changed
Improvements
- Improve GPS Rescue Pitch smoothing and disarming by @blckmn in #12413
- Fix unified targets that use OctoSPI. (BF4.4.x) by @hydra in #12307
- Increase FF smoothing max to suit elrs 1000hz link rate (#12426) by @limonspb in #12433
- Fix max permissible CMS rows and up/down page arrows (#12277) by @SteveCEvans in #12284
- Rollup 1 by @hydra in #12306
- Fix SDFT batchSize rounding by @KarateBrot in #12332
- Latest changes from unified targets, and sdcard build fix. by @blckmn in #12415
- H7 Fix frozen ADC values by @klutvott123 in #12443
- ICM426XX AA filter (#12444) by @sugaarK in #12465
- Blackbox (as applied to 4.5.0) by @blckmn in #12520
- DShot zero between beacon commands for 4.4, from 12544 by @ctzsnooze in #12555
- Restore DShot Beacon control for 4.4 by @ctzsnooze in #12560
- Include smartport telemetry for Fport (#12314) by @klutvott123 in #12572
- Exclude MSP_OSD_CONFIG if USE_OSD not defined (#12513) by @klutvott123 in #12590
- Add separate AAF values for ICM-42605 by @sugaarK in #12616
- Patch for config.h files by @blckmn in #12380
- Adding support for building by config by @blckmn in #12376
- FIX CONFIG: Adding USE_ACC, USE_GYRO and USE_BARO where appropriate. by @blckmn in #12477
- FIX CONFIG: Adding USE_FLASH to enable where hardware supports by @blckmn in #12499
