Battery weight GNB 4S HV - ?
Greetings to all.
I am building a 3.5" fpv-quadcopter and I don't want to exceed 250 grams. I will need to order Gaoneng GNB 4S HV xt30 batteries, but their weight is usually not accurate enough. I ask you to write the actual weight of your batteries 450mah, 530mah, 550mah, 650mah, 660mah. I have larger batteries, I know their weight:
GNB 4S HV 720mah 100C/200C xt30: 66.1g; 66.4g;
GNB 4S HV 850mah 60C/120C xt30: 68.1g; 68.5g;
GNB 4S HV 1100mah 60C/120C xt30: 86.6g; 86.64g;
Not all GNB or HV, but here is a snapshot of the 4s packs that I have. That GNB 850mah really underperforms compared to the other packs I highlighted in yellow for freestyle. Probably fine for a cruising pack, but I never tried it.
[Image: Ay302rh.jpg]
picture for reference:
[Image: G7egnfA.jpg]
[-] The following 2 users Like sevro's post:
  • AirriK, StSV
Thanks, it's very useful to see the weight of similar batteries from other manufacturers.
Just FYI, incase somebody is trying to get max mah per gram.. dont bother.
The 650mah or 850mah are just labels. If you buy the lightest 650mah, you will often find its not really 650mah or a low-C "long range" battery that degrades after 15-20 flights.
I'm running three yellow (90C) 2S 660 and they are past 100 cycles and still hold full charge. If you buy some shit no name 650mAh, then maybe, but all of my GNB's have been cycled many many times and still hold a reasonable amount of charge (or the same amount) and don't sag to the nth degree when i fly. I've never had a Lipo die after 15-20 charges, but I only run GNB and CNHL.
Try Not, Do or Do Not
- Yoda
GNB 4S HV 450mah 80/160C XT30
FOUR packs, 52.6 - 52.8 - 52.0 - 52.7
ACEHE 4S 450mAh 75C XT30 (Not HV, small velcro strip)
FOUR packs, 49.2 - 48.8 - 48.7 - 49.6
[-] The following 1 user Likes BadRaven's post:
  • LiPoFly
(02-May-2023, 06:59 PM)BadRaven Wrote: GNB 4S HV 450mah 80/160C XT30
Thank you! These numbers are very interesting to me, my drone weighs approximately 196 grams, and such batteries are quite accurate for < 250 grams.
(02-May-2023, 06:59 PM)BadRaven Wrote: small velcro strip
Been thinking of adding this to all of mine.  Kind of like having a double lock on your battery to hold it in place.  A strap and velcro.
- Yoda
  Discussion 4-6s battery charger advice balauru_327 11 560 19-Feb-2024, 03:57 PM
Last Post: jasc
  Li-ion Battery and Betaflight mlcasmey 11 1,397 26-Jan-2024, 01:18 AM
Last Post: StuweFPV
  Discussion Battery Dimensions segler999 2 235 19-Jan-2024, 05:39 PM
Last Post: segler999
  Need help finding battery replacement for T-drones Ares 6S 30Ah on US east coast Heimegut 1 245 15-Jun-2023, 10:46 PM
Last Post: Lemonyleprosy
  GNB 27 Connectors BadRaven 0 230 07-Jun-2023, 08:16 PM
Last Post: BadRaven
