11-Jun-2017, 07:45 PM
Hi to everyone, how can I choose the right battery for my quadcopter? In terms of mAh, discharge rate and weight? I have a martian 3 250mm, emax rs2205s 2600kv, racestar 30A lite s and omnibus f4 v2
Battery help |
11-Jun-2017, 07:45 PM Hi to everyone, how can I choose the right battery for my quadcopter? In terms of mAh, discharge rate and weight? I have a martian 3 250mm, emax rs2205s 2600kv, racestar 30A lite s and omnibus f4 v2 11-Jun-2017, 09:28 PM Like almost everything else in quadcopters, the answer is relative. To me, it looks as if you want speed! 2600kv motors can really ask for a lot depending on props. I personally would look for something reputable with a 75c or preferably higher discharge rating in a 1500mAh capacity size. You may save a bit of weight with a 1300mAh pack but might see more voltage sag. Target weight between 150g and probably no higher than 180 grams seems to be most common for 250mm 5" builds. Personally I am a fan of Tattu's. Just my 2 cents 12-Jun-2017, 01:03 AM If you are looking for packs for every day practice, these are pretty good value. http://bit.ly/infinity-4s-1500mah |
SPARKS WHEN I PLUG IN THE BATTERY | JakeTheNut | 4 | 88 | Yesterday, 05:05 PM Last Post: segler999 | |
Best Battery Option for Build - Begginer | Arkadius27 | 7 | 233 | 19-Mar-2024, 04:40 PM Last Post: Pathfinder075 | |
Smoke, Fire, and Sparks when I plug in battery | NickyWicker | 7 | 1,733 | 06-Mar-2024, 09:39 AM Last Post: home003 | |
4S vs 6S Battery Question | Coleon | 23 | 867 | 24-Feb-2024, 01:07 AM Last Post: iFly4rotors | |
How do FPV cars and planes transmit battery voltage to the pilot? | Brun0MF | 12 | 351 | 05-Feb-2024, 06:47 PM Last Post: Krohsis |
