Audio is starting to get worse and worse fuzzing out
I have the Fat Shark Scout, I recently (a few months ago) got the Steele audio bud and have been enjoying using it for a bit, recently it started to get a slowly growing to be worse buzz where I can now barely hear the actual props, does anyone know what the cause for this could be and how to fix it? I did have a very mild crash not to long before it occurred. Thank you as always!!!?
I have worked in bands and audio most of my life and a buzz almost always had to do with a bad or missing electrical ground. You say it slowly got worse which tells me an electrical component slowly went bad. Have you checked the jack/plug on the goggles to make sure nothing has built up there to block the ground. Also, I don't know if you have another earbud you can try just to make sure the wire connection on the earbud itself didn't go bad which can happen from the cable pulling on the ends.
I am not the best authority on quads, so there may be something else causing it.
[-] The following 1 user Likes brettbrandon's post:
  • Gabe Miller
In addition to what Brett suggested on the goggle side of things, take a look at the quad itself. You said you had a small crash- check the state of the microphone on your vtx- make sure it didn’t get partially knocked off, damaged, etc.
Dangerous operations.
  • Gabe Miller
I can check the blog and if it’s good I may just get a new earbud and keep you guys updated! Thank you!!!
  High Antenna worse than at ground Level?? Evaredy 5 409 01-May-2023, 12:29 AM
Last Post: Evaredy
  Caddx Turtle v2 - audio out? NiBe 8 1,638 08-Jul-2022, 04:19 AM
Last Post: mitsali
  OSD, smart audio but no video Junkrap 7 1,305 07-Dec-2021, 09:19 PM
  Help TBS Unify pro32 HV has built-in microphone, but no audio output from the goggles fabstar68 9 3,761 27-Nov-2021, 06:21 PM
Last Post: Kevin2112
  Help Rush tank mini S.Audio 2.1 but it behaves like 2.0.??? Rob3ddd 3 2,190 20-Jul-2021, 02:02 PM
Last Post: Rob3ddd
