Threads: 14
Likes Received: 2 in 1 posts
Likes Given: 16
0 I have the Fat Shark Scout, I recently (a few months ago) got the Steele audio bud and have been enjoying using it for a bit, recently it started to get a slowly growing to be worse buzz where I can now barely hear the actual props, does anyone know what the cause for this could be and how to fix it? I did have a very mild crash not to long before it occurred. Thank you as always!!!?
Threads: 17
Likes Received: 588 in 403 posts
Likes Given: 731
31 12-Sep-2022, 11:48 PM (This post was last modified: 13-Sep-2022, 02:32 AM by brettbrandon.) I have worked in bands and audio most of my life and a buzz almost always had to do with a bad or missing electrical ground. You say it slowly got worse which tells me an electrical component slowly went bad. Have you checked the jack/plug on the goggles to make sure nothing has built up there to block the ground. Also, I don't know if you have another earbud you can try just to make sure the wire connection on the earbud itself didn't go bad which can happen from the cable pulling on the ends.
I am not the best authority on quads, so there may be something else causing it.
Threads: 75
Likes Given: 3,949
121 In addition to what Brett suggested on the goggle side of things, take a look at the quad itself. You said you had a small crash- check the state of the microphone on your vtx- make sure it didn’t get partially knocked off, damaged, etc.
Dangerous operations.
Threads: 14
Likes Given: 16
0 I can check the blog and if it’s good I may just get a new earbud and keep you guys updated! Thank you!!!
