Back to the 250 class
I've always been a big fan of Armattan and even started out in mini quads with a prototype Morphyte I bought from MayMayDay back in the day. While I've been flying pretty much exclusively 150 class recently, I decided to get back to 5" props with the Armattan Chameleon Ti.
Aside from the name and the reputation that came with it, I was looking for the smallest form factor 250 class in their fleet and the Chameleon coming in at 220mm MTM was smaller than the Badger and Marmotte both at 236 and the Rooster at 230. I was also partial to the solid body and titanium camera cage (vs. alu for the original Chameleon).
This was to be a 6S build to really differentiate from my 4S 150 class. Parts used:
Holybro Kakute F7 AIO V1.5 Flight Controller
T-Motor F40 PRO III 1600KV
Spedix GS35 2-6S 32Bit 35A ESC
Fat Shark Byte Frost VTX (0b.CB.23 firmware)
TBS Crossfire Nano RX
Lumenier AXII 2 Stubby 5.8GHz RHCP Antenna
While I much prefer 4-in-1 ESCs for convenience and cable management, the 22mm stack height capacity of the Chameleon is really just about enough to accomodate 2 components in a stack and I needed that for the FC and Byte Frost VTX.
So this build really necessitated the use of individual ESCs. Also, it made me feel all old school again lol
Testing out the electronics before installation. Turns out I was tapping what I thought was a ground pad for the RX but was not. Good find.
First layer is a custom mount so I can secure both the Crossfire RX and a Matek 9V regulator. The Byte Frost is officially rated for 6S and I know of a racer that runs it straight off lipo at 6S but figured since these things are not easy to come by, I'd play it safe.
So while I spent a LOT of time making sure I had vertical clearance in this build ... I did not ever think *horizontal* clearance would be an issue. This was maybe the 3rd draft of the second layer. The issue was the massive 1000uf cap. Having it the way I normally would directly at the lipo slanting up a bit exceeded the 22mm stack capacity. From the bottom, I had the RX and Matek regulator limiting space. From the front, the antenna connector of the Byte Frost VTX was limiting space. And from the rear, the custom antenna mount was limiting space.
It all ended up fitting but a perfectly snug fit. Too perfect. I prefer a bit more room.
I used a custom mount for the Runcam Racer HD so I can get the lower angle I prefer.
All in all a tighter fit than I had planned for (horizontally not vertically).
The Byte Frost VTX can get very hot so I was hoping for more space between the stack. But I had to push wiring between the stack rather than keeping them in the rear because I had forgotten to take into account the huge size of the cap.
Otherwise, I think it turned out to be a very clean build!
Oh forgot to mention my coolio landing skids lol
Little nod to the days of the Naze32 and Blackout Mini H
Really stoked on my antenna mount design. This took so many iterations to get right lol. Even then I still had one hole I just could not find ended up using an online repair tool to fix it LOL.
Money shots incoming ...
Believe it or not, other than on a gimbaled Phantom from way back in the day, this will be first time I fly with a GoPro lol. Even when I flew 250 class before, we used Mobius cams.
Coming in at 670g auw with 6S 1030mah lipo and Session 5.
In a couple hours I will maiden Hope nothing blows up
