21-Sep-2022, 05:43 AM
Picked this printer up on a whim a couple weeks ago. This thing is working pretty good out of the box, setup was pretty easy and the few issues I've run into were easy search for and fix. I haven't spent a lot of time researching it as I've had very little reason to so far. PLA has printed pretty much flawlessly though I've only printed what I would assume are fairly easy prints. About the only hiccup was the initial layers bonding but cleaning the bed (came with PEI sheet) and slowing down the first few layers fixed those issues.
TPU prints do have a good bit of stringing and it took a few fails on some files to realize I need to be rotating some of these items in the slicer that I've downloaded from Thingaverse. While a camera mount hasn't come out flawlessly the zits and such for something that is going to be crashed is beyond good enough. The zits for example are on the underside of the 25 degree angle which I understand is more difficult to print such an angle.
But the first problem I have, I'm not sure how to go about finding the answer, searching for anything with "ender" and "3" brings up many iterations of this printer. On a couple of files like these:
https://www.thingiverse.com/thing:3863471
https://www.thingiverse.com/thing:3536894
The extruder seems to always jam the TPU on these files fairly early on. Like with the Hota screen protector it doesn't make it all the way through the first pass of infill lines. Similarly with the cup holder insert, it will fail somewhere on the first or second layer. If I catch it when it's happening while it's still running and thinks it's printing I can pull the filament out, cut the snag out and push the filament right back in where it resumes itself so it's not like the nozzle is clogged. Or I would cancel the print since it's already ruined and pull up another random TPU file and it prints it flawlessly. I've not measured it but it's like the snag is like 50mm or so from the nozzle.
Is there something in the slicer that needs to be tweaked for these? I've printed some battery pads that are similar to this and they come out with no issues and no jam. Why can I print another file that lays down more material than the fail job flawlessly right after by just cutting the kink out of the TPU and feeding it back into the hot nozzle?
