Hello forum,
finally got my first 5 inch second hand which was in pretty rough shape and came right out of a mud mask . After cleaning and setting (almost) everything up I'm now stuck, what feels right in front of the fnish line.
Three out of four motors are stuttering and producing a scraping sound as like as they had sand inside. So I already opened up one of the scratchy sounded motors and the only good one for comparision though they had some dirt inside motor didn't get better after some compressed air treatment.
After already watching a lot of videos and reading on the internet most people suggest to swap around motors and conclude from that if it is maybe the ESC or the motor. Though I could do that I could't fix it at the moment anyway since I'm in holidays resp. at family and there is nothing I could do about it. So my only hope would be, that there is something I forgot to set-up or configure....
Video:
https://www.mediafire.com/file/l156cbih9...7.mp4/file
As you can see Motor 2 (front-right) is doing well while the others are first scratching, twitching and jerking around and then getting turned off completely.
I can address all 4 motors from Betaflight. Also I can see all ESCs from BLHeli-Configurator (while from BLHeli-Suit I don't manage to connect at all, however guess that's just my or my PC's fault) BLHeli-Configurator is fine and I can see that 2 of 4 ESC's are in reverse.
I would have tried to update the firmware of the kwad since Betaflight is still 3.5.3 but I also cannot find the Firmware of the GEPRC Mark 2 on the webpage of geprc.com maybe somebody has a hint on this as well?
Also tried to calibrate the motors in the motor tab of Bataflight though I'm not sure it was successful. Though I heard the second special meleodie for "low output" I think i miss the first/starting melodie for "high output".
In the attached screenshot you can see the motor output of 50% throttle (coming from 0% throttle).
So I'm asking for your input and hoping for "this-hidden-switch" I forgot to tick. Thanks in advance
Wasp
Video:
# Betaflight / OMNIBUSF4SD (OBSD) 3.5.3 Nov 15 2018 / 00:20:01 (61d5abf00) MSP API: 1.40
board_name OMNIBUSF4SD
manufacturer_id
mcu_id XXXXXXXXXXXX-censored-XXXXXXXXXXXX
signature
# name
name Mark2
# resources
resource BEEPER 1 B04
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 A01
resource MOTOR 6 A08
resource MOTOR 7 NONE
resource MOTOR 8 NONE
Wasp
