1st Quad Build HELP!
Hi,
I'm new to the forum. I've been flying a basic quad which is only just a step up from a toy with a ton of sensors and auto level. I'm interested in building my own quad for a bit of acrobatics and maybe some basic racing in the future (but will most likely upgrade before then). I'm into electronics and don't mind soldering and would like to put together my own quad. I've done some research and watched loads of reviews and I've put together my list of parts for this build. I've got a few things that I'm not sure about highlighted in red that I am still unsure about in the attached Spreadsheet. Just wondering if someone with a bit more experience could take a look and see if there's anything missing or if I'm making any rookie errors. The spreadsheet contains all the pricing some specs which i think are right and links to where I'm currently proposing to buy them from.
Let me know if there's anything missing. And I do have, I think, all the tools and things required extra such as: heat gun, soldering iron, spare heat shrink, cable ties ect.
Thanks a lot in advance!
(for anyone that cant get to the spreadsheet here's a list of parts belowSmile
Turnigy Evolution controler+reciever
Emax RS2205 motors
Quanum Cyclops V2 Goggles
Infinity 4S Graphene LiPo*2
RunCam Swift 2 Camera
CL Racing F4S FC
Martian 220
FuriBee BLHeli - 32 30A
Imax B4AC 50W 2-4S charger
Gemfan 5x3 Propeller *5 sets
Eachine TS5823S Video Trans.
5Pcs RJX Battery Straps
Ps. Don't worry about Orange bits, They're on Order!
Lipo is too heavy. 1300mah to 1800mah. 1300mah - 1500mah being the sweet spot. High C rate, 70C or more.
I would go F4 AIO and lose the PDB. Racing CL F4S or Joshua Bardwell FC.
Frame, Martian II
You will need more than two sets of props.
  • lukeocartwright
(02-Jan-2018, 10:34 PM)voodoo614 Wrote: Lipo is too heavy. 1300mah to 1800mah. 1300mah - 1500mah being the sweet spot. High C rate, 70C or more.
I would go F4 AIO and loose the PDB. Racing CL F4S or Joshua Bardwell FC.
Frame, Martian II
Thanks really appreciate it! I'll change those bits out you mentioned and yeah i think the props was a bit of an underestimate.Thanks again!
Hey Luke, welcome to the forum man.
Just a heads up... I have never used them but the ZOP batteries from BG are often called Zero Output Power.
If the budget allows I would suggest going for the Tattu R-line 95C ($35.99) or 75c ($28.79)
Poor quality batteries are simply  not worth the money.
Another thing about the charger... That charsoon only has 25W output power so really will only charge 1 battery at a time, if you want to get more batteries in future I would recommend getting a 'para' board (parallel charging board) and a slightly higher wattage charger, like the iMax B6-AC (50W).
Anymore questions, just shout mate!
  • lukeocartwright
(03-Jan-2018, 04:15 PM)Tom BD Bad Wrote: Hey Luke, welcome to the forum man.
Thanks for the heads up on the battery i was wondering why it was so much cheaper than all the others. Ill also have a look around for another charger and see if there's anything at a decent price
I got a whole bunch of ZOP batteries from Banggood, and they are actually pretty good quality batteries. They do the job well for a cheap price. If you want to get a lighter ideo transmitter, consider the Eachine VTx03. Even though it has a dipole antenna, it is cheap, light, and easy to install. Your build list looks very good. If cost is your number one option here, go for the ZOPs, but if you are willing to pay a bit more for higher quality batteries, then get some better ones.
If it ain't broke, DON'T FIX IT!
My YouTube FPV Channel
(03-Jan-2018, 09:21 PM)raspberrypi33 Wrote: I got a whole bunch of ZOP batteries from Banggood, and they are actually pretty good quality batteries. They do the job well for a cheap price. If you want to get a lighter ideo transmitter, consider the Eachine VTx03. Even though it has a dipole antenna, it is cheap, light, and easy to install. Your build list looks very good. If cost is your number one option here, go for the ZOPs, but if you are willing to pay a bit more for higher quality batteries, then get some better ones.
Thanks for the info I'll do a few calculations and read a few more reviews to see if its worth the upgrade.
You may want to step up the props to 5 X 4.5, those 5 X 3 won't give you much lift
  • lukeocartwright
(04-Jan-2018, 12:51 AM)RENOV8R Wrote: You may want to step up the props to 5 X 4.5, those 5 X 3 won't give you much lift
Thanks I'll take another look at the motor specs and see what it says. I don't want too much lift to start with though as my current quad is really tamed down and I don't want to be trying to run before i can walk. I'll probably get a few sets of each so as soon as im used to it i cans swap out.
Welcome Luke! This is a wonderful forum of knowledgeable and helpful folk!
I have the B6 charger and love it! I parallel charge my XT30 and XT60 batteries with it all the time and it does a wonderful job.
I will second (third or whatever) about resisting the urge to buy cheap batteries. I have shifted almost all of my batteries to Tattu or Lumeneir and have had zero issues since. The ZOP and XF-Power batteries are in a box...collecting dust...they really ended up not being worth the expense in wait time to order. Every gram counts in this hobby and when the battery comes close to outweighing your aircraft, it will adversely effect your flight performance. The benefit of the extra cost of premium packs is that they tend to weigh a lot less and have a more quality control applied.
When I started flying, I ordered a few boxes of cheap props and thought they were great...until a vendor sent included some "expensive" ones as a freebie. The difference in smoothness is incredible! I am glad I started with the cheap ones and I cannot count how many three bladed became 1 or 2 bladed. As your skill increases, it is well worth trying out the $4 and $5 dollar sets, but for learning, KingKongs and the like are fine.
Main thing, have fun flying!
SoCal Kaity :D
[-] The following 1 user Likes kaitylynn's post:
  • lukeocartwright
Thanks to everyone for all the advice its all on order and hopefully as soon as it all gets here I'll get it together without any issues (seems unlikely but I can hope). Really appreciate all the advice!
[-] The following 1 user Likes lukeocartwright's post:
  • Tom BD Bad
Exciting times! Let us know when the stuff arrives and if you have any troubles with it...
Hi all the parts have come through! Got everything together and plugged it in to configure with beta flight. When i connected the battery to my CLRacing F4S board some of the motors started to twitch. I realised this was a short circuit issue which i then resolved. It connected to Betaflight and was fine as i began setting up. However after getting to the ports page on betaflight the board red Led's went off and it disconnected from Betaflight. I am as yet to find a way to reconnect it. No LED's come on when i connect it via battery or USB but the board is definitely getting power to the esc's and they are beeping when plugged in. Anyone got any ideas would be a great help! If not it looks like I'll Have to buy another flight controller.
Thanks In advance.
If none of the LEDs on the flight controller light up, then it sounds like it's dead.
Where was the short circuit that you had? Maybe that caused the problem.
Some pictures of how you've put everything together would really help.
#15
The short circuit was on two ESC connectors on the FC (+ and signal) being just about connected. I will try and add some photos of the build.
  Who wants to help me to build my first FPV? Several questions and concerns about how phelipems 3 96 13-Apr-2024, 12:09 AM
  Need help with quad drifting…. danny 20 1,006 06-Apr-2024, 04:53 PM
Last Post: infrared4ever
  First Build - prevent antenna chop? JohnnyCornRocket 5 202 28-Mar-2024, 02:16 PM
Last Post: iFly4rotors
  Best Battery Option for Build - Begginer Arkadius27 7 227 19-Mar-2024, 04:40 PM
  Anyone ever X-Ray a quad? Rob Axel 0 103 18-Mar-2024, 06:54 PM
