Hi everyone!
After enjoying my tiny whoop a few months finally I bought a Diatone Roma F5 6S. But my XM+ won't bind to the tx16s. Before soldering the XM+ to my Roma F5's FC, I flashed the "XM+_ACCST_2.1.2_LBT_RSSI16" firmware to the XM+. I tried with "FrskyX2 LBT(EU)" protocol on the tx16s since the information here says: "FrSky receivers running ACCST v2 firmware should use the FrSkyX2 protocol - they are not supported by this protocol." I tried other protocols too. When I keep the tiny button on XM+ pressed and plug in the battery, both green and red lights light up solid. So, no solid green and flashing red light as it should be. What could be the problem?
Apart from this problem, the quad makes a short popping noise the moment I plug in the battery. I can't determine where it comes from but it sounds like it comes from the XT60 plug. Is that possible? After plugging and unplugging the battery many times I noticed that more and more black marks started to appear on the XT60 plug of the battery. Is that normal?
Thanks for your help.
