Wiring for Diatone Mamba F722 with FrSky R9 mini and or R9 slim
Hi
I am building my first quad, I have pretty everything under control  (I hope) but for the wiring of the Mamba F722 with either a FrSky mini or slim, I have he two radios.
The der wire goes to 5V, Black wire goes to Ground.  then wich one to use for Sbus and or F port?
Dod you have any wiring info or diagram for these two items?
I tried to contact Diatone, but did not get an answer, Looked around this forum also. Nada. Niente, Rien, Que Dale!
Thanks
here is the hook-up wiring.
[Image: GJZLosjl.png]
Here's a link to a full size version of the same diagram that Voodoo posted which you can zoom into...
Thanks, I have this diagram already, but it does not show the connections using a R9 slim or mini. Thanks
Flash the latest version of the FLEX firmware to both the R9M module and the R9 Mini/Slim receiver. On the R9 Mini/Slim make sure you use the FPORT version of the FLEX firmware.
Make sure the version of OpenTX flashed to your transmitter has the "flexr9m" option ticked.
Then make the following connections:-
  1. S.Port pad on the R9 Mini/Slim to the TX2 pad on the F722S.
  2. 5V pad on the R9 Mini/Slim to a 5V pad on the F722S.
  3. GND pad on the R9 Mini/Slim to a GND pad on the F722S.
I suggest you use pads for 5V and GND that are in the same row of pads as TX2 to keep the wiring neat.
Then run the following commands in the CLI...
set serialrx_provider = FPORT
set serialrx_halfduplex = ON
set serialrx_inverted = ON
save
Check out Oscar's blogs on this (he owns this place) ...
https://oscarliang.com/setup-frsky-fport/
https://oscarliang.com/setup-r9m-r9-mini-betaflight/
Mind which pad you are soldering since the SBUS and FPORT are different.
If you are using SBUS, solder to the "SBUS" pad on the FC - it is just left of the cobra image on the left side of the FC (colored green in the linked diagram). You'll notice you've got a 5V and GND right near SBUS to keep the wiring neat like Snow said.
If you are using FPORT, it's just as Snow described tapping it to a TX pad on the FC. Technically you can use any unused TX pad but Snow suggested TX2 because as with SBUS, it's near a 5V and GND pad for clean wiring.
Fabulous, thanks this is all I needed.
Hi
I just finished setting it up and finally it is working, all I need to do is tidy up the wires, install the top plate, check the camera setting and give it a try.
Hope it flies.
Thanks again for all the help
[Image: DhjfRn8l.jpg]
[-] The following 2 users Like Fizou's post:
  • kaitylynn, the.ronin
Well, get it in the air already, hehe.
Deal
Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire.  Tinyhawk, Tinyhawk S, and a DJI Spark.  And projects on the bench....
Well, it looks I am not finished. The radio, the Mamba fc F722 and the R9M mini are wired and working. I have telemetry showing up on my radio (Jumper T16). The GPS is also woking, and showing up on Betaflight.
I had the camera (Caddx Turbo micro) directly connected to the VTX (ground, 5 volt, video), the VTX was then connected to the 9v pad and the ground one next to it on the right side of the fc.
I got video on my goggles and screen. But then I realized I was not getting on the video any of the telemetry I selected in Beyaflight.
I found out that I need to have the camera and the VTX both connected to the FC in order to get telemetry on the screen, or goggles
I plan to connect the camera to the pads: ground, 5v, and cam, then the vtx connected to the 9v, ground and tX3 (for video) on the right side of the FC. But, but, I am left with an audio white wire from Camera, and also a smart audio vire on the VTX. Where do I connect this two wires on the FC in order to get audio?
Any idea?
Thanks
No idea on audio but the smartaudio connects to RX3 which is right next to the vid pad in the diagram shown above.
Once connected go into ports in Betaflight and enable smartaudio on UART3 and all should be good.
I had a look at your picture and your wiring looks wrong. The camera connects to the pads right next to the esc plug at the front of the pcb. The pad labelled CAM is where the camera should be connected to.
(10-Jan-2020, 06:53 AM)UrbanJungle1966 Wrote: No idea on audio but the smartaudio connects to RX3 which is right next to the vid pad in the diagram shown above.
Smartaudio is connected to UART TX not RX.
(10-Jan-2020, 08:09 AM)voodoo614 Wrote: Smartaudio is connected to UART TX not RX.
Yes sorry didn't have my glasses on. TX3 is where it is connected to which is right next to the VID pad.
Thanks, I disconnected the camera and the VTX, I will try tomorrow to rewire them correctly. Thanks again
Fizounet
#15
(10-Jan-2020, 06:38 AM)Fizounet Wrote: I had the camera (Caddx Turbo micro) directly connected to the VTX (ground, 5 volt, video), the VTX was then connected to the 9v pad and the ground one next to it on the right side of the fc.
Any idea?
Thanks
To get OSD, you have to wire the camera signal through the FC.
To wire camera, yes you are correct. So you camera can take 4-40V. Why don't you use the 9V next to the CAM. So 9V, ground and CAM.
The wire wire is audio. Your camera has a built in microphone. You normally wire the audio wire straight to the VTX if it has audio input. If you don't have an audio input or do not care for audio, then you can ignore the white audio wire.
You Smartaudio question was asked above. Smartaudio to free UART TX.
  Help Frsky XM+ Firmware versions Steak-9 3 113 26-Mar-2024, 01:28 PM
Last Post: Steak-9
  Help FrSky r xsr receiver not entering bind mode August 1 98 05-Mar-2024, 08:49 PM
Last Post: August
  Help FrSky Archer RS to Speedybee F405V4 through F.Port trecords 0 120 28-Jan-2024, 09:10 PM
Last Post: trecords
  Problem with FRsky R9 900mhz PJKMBAKER 5 345 24-Dec-2023, 02:18 PM
Last Post: PJKMBAKER
  E8 transmitter Armattan Chameleon frsky binding Ed_FPV 1 183 03-Dec-2023, 04:38 PM
