04-Jan-2022, 05:48 PM (This post was last modified: 04-Jan-2022, 05:50 PM by Mr_Stripes.)
Hi all,
I have built a 65mm whoop with:
Happymodel diamond f4
Happymodel ex0802 19000kv
Runcam nano 3
Meteor 65 frame
Mobula6 canopy
I have it on the project mockingbird emuflight tune. It is running emuflight 0.3.4. When I arm and put any input in it instaflips. I think it has something to do with the props in/out but I cant think of what as i have gone through everything that I know of. When I hold it in my hand and arm it does that weird thing where if you hold it loosely it wobbles around but when you hold it tight it stops. I have reversed and unreversed the escs and tried every combo of esc direction and props in/out imaginable. Is there anything you guys can think of? Im fresh outta ideas. Did I do something dumb that is right in front of my face? And I almost forgot, the board is flipped over. I have already re mapped the motors and set the gyro roll angle (or whatever it is in the config tab) to 180 degrees.
Any input is appreciated,
Mr_Stripes
Here is my cli dump
# diff all
# EmuFlight / CRAZYBEEF4FS (C4FS) 0.3.4 Apr 16 2021 / 19:24:07 (1014a9331) MSP API: 1.50
board_name
manufacturer_id
mcu_id 005a004c5231501620323039
signature
defaults nosave
# name
# resources
resource MOTOR 1 B06
resource MOTOR 2 B10
resource MOTOR 3 B08
resource MOTOR 4 B07
# mixer
# servo
# servo mix
feature -AIRMODE
feature LED_STRIP
# beeper
# beacon
# map
map RETA1234
serial 1 2048 115200 57600 0 115200
# color
# mode_color
aux 0 0 0 1700 2100 0 0
aux 1 1 1 1700 2100 0 0
aux 2 2 1 1300 1700 0 0
aux 3 28 1 900 1700 0 0
aux 4 30 1 1300 2100 0 0
aux 5 35 2 1700 2100 0 0
# adjrange
adjrange 0 0 1 900 2100 12 1 0 0
# rxrange
# vtx
# rxfail
# master
set gyro_lowpass_hz_roll = 200
set gyro_lowpass_hz_pitch = 200
set gyro_lowpass_hz_yaw = 90
set imuf_roll_q = 4000
set imuf_pitch_q = 4000
set imuf_yaw_q = 4000
set imuf_w = 16
set imuf_sharpness = 6000
set acc_calibration = -112,34,-49
set max_check = 2000
set fpv_mix_degrees = 90
set cinematic_yaw = ON
set airmode_start_throttle_percent = 40
set min_throttle = 1035
set dshot_idle_value = 500
set align_board_roll = 180
set bat_capacity = 300
set vbat_max_cell_voltage = 45
set vbat_min_cell_voltage = 30
set vbat_warning_cell_voltage = 31
set yaw_motors_reversed = ON
set crashflip_power_percent = 100
set pid_process_denom = 2
set runaway_takeoff_prevention = OFF
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = OFF
set osd_warn_dji = OFF
set osd_rssi_pos = 2081
set osd_tim_1_pos = 2102
set osd_flymode_pos = 2455
set osd_craft_name_pos = 2441
set osd_warnings_pos = 2409
set osd_avg_cell_voltage_pos = 2433
set vtx_band = 5
set vtx_channel = 8
set vtx_freq = 5917
# profile
set smart_dterm_smoothing_roll = 50
set smart_dterm_smoothing_pitch = 50
set witchcraft_roll = 0
set witchcraft_pitch = 0
set spa_roll_i = 75
set spa_pitch_i = 75
set spa_yaw_i = 45
set crash_recovery = ON
set iterm_rotation = OFF
set throttle_boost = 0
set feathered_pids = 0
set i_decay = 7
set emu_boost = 0
set emu_boost_yaw = 0
set emu_boost_limit = 0
set emu_boost_limit_yaw = 0
set p_pitch = 95
set i_pitch = 85
set d_pitch = 85
set p_roll = 95
set i_roll = 85
set d_roll = 85
set p_yaw = 120
set i_yaw = 85
set d_yaw = 0
set d_angle_low = 35
set p_angle_high = 80
set level_limit = 80
set horizon_tilt_effect = 0
# profile
profile 1
set pid_at_min_throttle = OFF
set spa_roll_i = 75
set spa_yaw_i = 45
set i_decay = 7
set emu_boost = 400
set emu_boost_limit = 55
set p_pitch = 85
set i_pitch = 75
set d_pitch = 75
set p_roll = 85
set i_roll = 75
set d_roll = 75
set p_yaw = 100
set i_yaw = 75
set d_yaw = 0
set p_angle_low = 25
set p_angle_high = 10
set horizon_transition = 80
# profile
profile 2
# rateprofile
set roll_rc_rate = 200
set pitch_rc_rate = 200
set yaw_rc_rate = 205
set roll_expo = 24
set pitch_expo = 24
set yaw_expo = 20
set roll_srate = 60
set pitch_srate = 60
set yaw_srate = 22
set rate_center_sensitivity = 55
set rate_end_sensitivity = 125
set rate_center_correction = 25
set rate_end_correction = 75
set rate_center_weight = 50
set rate_end_weight = 40
# rateprofile
rateprofile 1
set roll_expo = 24
set pitch_expo = 24
set yaw_expo = 20
set roll_srate = 60
set yaw_srate = 22
# rateprofile
rateprofile 2
set roll_rc_rate = 1
set pitch_rc_rate = 1
set yaw_rc_rate = 210
set roll_srate = 0
set pitch_srate = 0
set yaw_srate = 0
# rateprofile
rateprofile 3
# rateprofile
rateprofile 4
# rateprofile
rateprofile 5
rateprofile 1
# save configuration
save
Runcam nano 3
Meteor 65 frame
Mobula6 canopy
Mr_Stripes
Here is my cli dump
# diff all
board_name
manufacturer_id
signature
defaults nosave
# name
# resources
# mixer
# servo
# servo mix
feature -AIRMODE
feature LED_STRIP
# beeper
# beacon
# map
map RETA1234
# color
# mode_color
# adjrange
# rxrange
# vtx
# rxfail
# master
set imuf_w = 16
set vtx_band = 5
set vtx_channel = 8
set vtx_freq = 5917
# profile
set spa_roll_i = 75
set spa_yaw_i = 45
set i_decay = 7
set emu_boost = 0
set p_pitch = 95
set i_pitch = 85
set d_pitch = 85
set p_roll = 95
set i_roll = 85
set d_roll = 85
set p_yaw = 120
set i_yaw = 85
set d_yaw = 0
# profile
profile 1
set spa_roll_i = 75
set spa_yaw_i = 45
set i_decay = 7
set emu_boost = 400
set p_pitch = 85
set i_pitch = 75
set d_pitch = 75
set p_roll = 85
set i_roll = 75
set d_roll = 75
set p_yaw = 100
set i_yaw = 75
set d_yaw = 0
# profile
profile 2
# rateprofile
set roll_expo = 24
set pitch_expo = 24
set yaw_expo = 20
set roll_srate = 60
set yaw_srate = 22
# rateprofile
rateprofile 1
set roll_expo = 24
set pitch_expo = 24
set yaw_expo = 20
set roll_srate = 60
set yaw_srate = 22
# rateprofile
rateprofile 2
set roll_srate = 0
set pitch_srate = 0
set yaw_srate = 0
# rateprofile
rateprofile 3
# rateprofile
rateprofile 4
# rateprofile
rateprofile 5
rateprofile 1
save
