Threads: 3
Likes Received: 1 in 1 posts
Likes Given: 9
0 So far out of the battery manufacturers I have used are,
1. tattu which have been the best with dual 1s 450mah 95c hv.
2.cncb which we're pretty crappy
3. Emax stock which were also pretty crappy.
But seeing how I'm looking for a 2S battery to go with for the freestyle which I already modded out and added a XT 30 plug along with my duel jct stock plugs I really don't know what to use Can you guys give me a list of some good battery manufacturers and some of the best battery manufacturers. I want to try them all so whatever info you guys got for me much appreciated. thank you
Threads: 66
Likes Received: 352 in 254 posts
Likes Given: 490
12 I find my 450mah batteries a bit heavy as it makes the quad slide a fair bit more than my 300mah batteries. No idea what brand I am using in the 300's as the stickers have come off.
I get just over 4 minutes on the 300's
Threads: 3
Likes Given: 9
0 No kidding. I always thought a 300mah wouldn't be enough power
Threads: 172
Likes Received: 2,296 in 1,843 posts
Likes Given: 4,746
103 300mah would be more „powerfull“ because of the weight but less flighttime...
Threads: 3
Likes Given: 9
0 So do you have a pretty good battery manufacturer you could recommend? I've been using tattu but perhaps you have something better?
Threads: 172
Likes Given: 4,746
103 22-Sep-2019, 01:47 AM (This post was last modified: 22-Sep-2019, 01:50 AM by hugnosed_bat.) the best 300mah batterys i know are turnigy nanotech, both the old 35c/70c and the new 70c/140c. very sadly they arent in the comparison of oscar...
i like gnb and ahtech infinity graphen aswell.
i beleive a heavy 450mah lipo would be more easy to fly because of lower power to weight ratio, less weight and more power will be difficult to fly, give more work on the stick, but will give more abilities.
Threads: 172
Likes Given: 4,746
103 oscar could you test the turnigy aswell? would be very nice, i would be very intressted in a comparison.
try diffrent one would be the best, diffrent flystyles diffrent personal preference. different props.. diffrent results aswell
