Threads: 25
Likes Received: 6 in 5 posts
Likes Given: 3
4 05-Feb-2016, 01:50 AM (This post was last modified: 05-Feb-2016, 01:50 AM by CurryCat.) Idea needed!
Just bought myself a Tweaker 180 frame
so wondering what is the most power yet smooth setup for this size mini quad?
Threads: 22
Likes Received: 1 in 1 posts
5 I saw Oscar's Airhog 180 build was pretty sweet:
I believe he's using Dragonfly 2206 2800KV motors with littlebee 20A ESC, and runs 4045 Bullnose props
I know RCX 2633kv or even 2950kv are also pretty good too, but I heard too many stories of failing motor bells, they just pop off during flight
2300KV motors are okay like Cobra 2204 2300KV... but they are getting slow now in today's standard
As for FC, maybe you want to try the new KISS FC and ESC too
![Smile Smile](https://intofpv.com/images/smilies/smile.png)
if not, I would probably recommend the Dodo with SBUS, or Naze32 Rev5 either with D4R-II, or SBUS with uninverted hack
Threads: 0
Likes Received: 0 in 0 posts
0 That depends on which tweaker frame you have, the standard or the FPV addiction model. The biggest motors you can comfortably fit on the standard are 18xx size while the other was made for 21-22xx size motors. I have the standard myself and use 1806 2300kv T-Motors on 4s which is a blast. If I could do it again I would probably go for the FPV addiction frame and some Rotorgeeks 2205 2700kv motors which are specifically made for 4" props and can push up to 1000g each.
