What's the best BLheli FW/Setting for fixed wing?
Hi all,
setting a fixed wing with a blheli-32 esc (succex x80a). What's the best fw or option set to begin with? motor is a an inrunner with gearbox and folding prop. Actually i would not let prop fold, but instead i want to let it spin so it can be used as airbrake. My fear is about returning current which can fry ESC, so any advice is welccome
I think the only firmware for wings is iNav.  Can't help you with your other questions.
EDIT: I misread your post.
turn the braking off for wing.
Thanks Vodoo. My concern is about if there's a proper version of blheli for fixed wing, like there's one for traditional helicopter. Other than disabling brake, i need also a number of other options, like a smooth throttle curve, not the steeper one of multi's
(20-Apr-2020, 04:05 PM)GlidLov Wrote: Thanks Vodoo. My concern is about if there's a proper version of blheli for fixed wing, like there's one for traditional helicopter. Other than disabling brake, i need also a number of other options, like a smooth throttle curve, not the steeper one of multi's
Throttle curve would be setup in the radio if you do not use a FC. If you have a FC for your wing, then you can setup in the flight controller software (iNav).
  Trying to fix GHF411 - motor barely moves. No BLHeli chime romangpro 0 192 22-Aug-2022, 07:21 AM
Last Post: romangpro
  HSKRC ESC 45A 2-4S BLHeli-S DSHOT600 fra_gra 2 605 04-Jul-2022, 01:18 PM
Last Post: fra_gra
Question Motor Poles - Betaflight setting BadRaven 4 3,533 22-Feb-2022, 12:16 AM
Last Post: kafie1980
  Solved T-Motor F55A 4in1 --> 2 esc's not showing in BF and BLHeli RobinS 7 2,017 23-May-2021, 06:49 AM
Last Post: Kevin2112
  Setting up Favourite Swallow 60A ESC's on a multirotor RaxorFPV 7 798 09-Nov-2020, 08:32 PM
