Threads: 1
Likes Received: 1 in 1 posts
0 I started flying in horizon mode today and while just running a quick pack the quad seems to lean left after a roll but doesn’t move left. If I fly a little it levels itself out. I was flying line of sight. Other then rates I haven’t adjusted anything. It’s a Arris x220 v2. It flies fine in angle mode. My guess is its either a setting in Betaflight or my accelerometer gets confused coming out of the roll. I am learning acro mode but thought I would fly in horizon mode for a while.
Threads: 125
Likes Given: 99
388 If softmount doesn't work, try increasing your acccy_deadband
set accxy_deadband = 80
Threads: 125
Likes Given: 99
388 Doesn't look soft mounted from the photo you posted.
Threads: 1
0 Just wanted to say thank you to all that helped. I soft mounted the FC but when i took it apart I found a broken standoff. I got it all squared away and the issue has been resolved. Thanks again.
