Hi!
I have only build a small Cine Rat, and I totally love it! However, I will like to learn more about the technology and also be able to fly long range.
In Spain to be able to fly long range, it is compulsory that the aircraft flies following a waypoint pattern. I understand that you can program a waypoint pattern on your PC using an Ardupilot FC or using a software called INAV.
I see most standard FCs include a port for GPS, but I do not know if this only allows to record the take off position to be able to perform a RTH, in case of signal loss, or if those FC also allow to program waypoints without using Ardupilot?
In case this is only possible using Ardupilot or INAV, which one you recomend?
Thanks a lot for your inputs, I hope that the questions I ask will also serve to other newbies.
Cheers,
Oriol
Cheers,
Oriol
