Threads: 2
Likes Received: 0 in 0 posts
Likes Given: 1
0 I’ve owned a few dji vistas and air units in the past, and usually applied the FFC hack to get 8 channels, etc, and this has always worked perfectly.
Recently though I’m have trouble accessing the vistas on board storage when plugged into my PC, everything’s powered on and ready, but only two ‘grayed out’ drives appear, which I don’t have access too. So can’t copy the text document over to apply the hack. I thought this might be a Windows 10 issues, but having the same issue with windows 7. Any ideas what this could been, Or other ways to apply the hack?
Threads: 13
Likes Received: 106 in 56 posts
Likes Given: 62
8 Is it just one Vista you're having trouble with, or all of them now?
Threads: 2
Likes Given: 1
0 It’s just the vista. Air Units fine
Threads: 580
Likes Received: 8,901 in 6,582 posts
Likes Given: 1,424
784 Try (re)flashing the V01.00.06.06 firmware to the Vista using the DJI Assistant 2 (FPV series) software in case your problem is caused by corrupt firmware. Then try again to see if that solves your issue.
Threads: 0
Likes Given: 7
0 I stumbled upon this issue myself and thought my Vista was dead but got it working. From my understanding the vista's internal drive only pops up in Windows when you have your goggles turned and connected to the Vista.
Can you give that a try and see if that works?
Threads: 2
Likes Given: 1
0 14-May-2022, 08:50 AM (This post was last modified: 14-May-2022, 08:51 AM by cloudbasefpv.) Thank you all the replies, much appreciated.
Shame these systems aren’t unlocked by default, be much easier!
Threads: 38
Likes Given: 430
118 They are locked to meet regulations and beyond that the onus is on the user unlocking it.
