This is on a Fettec FC/4 in 1 ESC but I'd imagine the principles are the same as betaflight.
The other day I soldered a new XT60 wire to my 4 in 1, as the old one got chopped up pretty badly. Conformal coated where I had soldered, since the rest of my board is coated as well. Today I went to plug in and I get white and black lines across the display, no OSD or anything.
The VTX is a Unify Pro so it takes up to 26V. I tried running it off the FC's BEC power as well as straight from the battery leads on the 4 in 1, and I get the same results. Removed the capacitor altogether, same results. I checked the voltage on the battery leads and it's showing the proper voltage. Everything else works - motors, everything. The VTX also powers on just fine, I see the LEDs.
I took a known working VTX off another quad and soldered it up, but instead of black and white lines, I get just black. Nothing else. I'm starting to wonder if my FC or ESC has a problem. Any other ideas?
Proud team pilot for brands I love: Dquad - Happymodel - Gemfan
