Sort of a one off question here.
I have a bunch of 12V peripherals (VTX, LEDs, FPV Cam). These are all being powered off the 2S lipo with a Polulu 7A 12V step-up reg. Rather than splicing a bunch of power leads together, can I just use a PDB and its ESC pads for cable management?
Specifically ...
2S Lipo --> Polulu 12V step-up --> PDB --> 12V devices off the ESC pads
I've tallied up the amp draw and it comes out to 1A without the LED bar which I can't get amp draw specs for (and my MM doesnt have amp reading). So let's assume double it to 2A. The Polulu has a lot of overhead at 7A but will a typical PDB be able to handle 2A draw? I'm assuming this should be nothing since most of our tiny quads are rated at 25A-30A.
The specific PDB I plan to use is the 30x30 Armattan Japalura PDB for which I can't find specs.
Specifically ...
