Be aware that this migrator tool doesn't appear to be fool proof, so use it with care. It might be safer for most people to just manually set up Betaflight 4.3.x on a quad from scratch using the Betaflight Configurator GUI.
One specific example I can give is the bi-directional DSHOT setting (the
dshot_bidir CLI command in the diff file). The migrator tool lists this as a SAFE command that can be run directly in the CLI. However, if you change the value of the Bidirectional DShot setting in the Betaflight Configurator 10.8.0 GUI (found on the Motors tab), it also makes changes to other (filter) settings that have a dependency on the value of Bidirectional DShot.
Betaflight 4.3.0 has Bidirectional DShot switched OFF by default and has the following Dynamic Notch Filter settings as default values:-
If you simply just run the "set dshot_bidir = ON" command in the CLI, Bidirectional DShot gets enabled but any Dynamic Notch Filter settings remain
unchanged and remain at the defaults as per the image above. However, if you manually switch on Bidirectional DShot in the Betaflight Configurator GUI, you get a warning message telling you that some of the Dynamic Notch Filter settings have been automatically changed, which indeed they have as shown below (Notch Count from 3 to 1, and Q factor from 300 to 500). So by simply running the "dshot_bidir" command in the CLI, it isn't also changing any of the dependent filter settings to their safe default values.
So clearly the "dshot_bidir" cannot be considered a SAFE command to just simply be run into the CLI from a prior version of Betaflight. This is just one command that I have discovered which has dependencies. There may be others, so keep that in mind if using this migrator tool or if you are hand picking commands to run in yourself. The only safe option is probably to just set everything up from scratch again for a quad that has been upgraded to Betaflight 4.3.x using the Betaflight Configurator GUI so that any dependant values elsewhere will also get automatically applied.
