10-Dec-2018, 12:39 AM
(09-Dec-2018, 11:53 PM)yoomoo Wrote: I knew i could'nt sleep without testing it
And you're totally right voodoo614, it was turtle mode![]()
Thanks a lot to all. You made my day.
cu Juergen
Nice work from Voodoo. Some deserved rep applied to his account
![Smile Smile](https://intofpv.com/images/smilies/smile.png)
I'm guessing you've disabled the switch position warning on the Taranis (or configured certain switches not to throw a warning) otherwise you'd have been warned that of any switches that were flipped from the downward/backward position. It might be a good idea to either re-enable that warning or make sure certain key switches provide a warning message.
While the UR65 doesn't come with a buzzer fitted, another thing you might want to consider doing is to turn on the motor beacon which can be used as a poor man's buzzer whereby it the motor are used to produce a sound instead of the buzzer although it's quite a bit quieter than a normal buzzer. Still, it's better than nothing if you don't want to fit a buzzer. The only thing I'm not sure about is if the motors will sound when turtle mode is activated because the motors can only make a beeping noise when they're not actually running. I can't test that on mine because I have a buzzer installed but something maybe worth trying. I'm sure Voodoo will know
![Big Grin Big Grin](https://intofpv.com/images/smilies/biggrin.png)
