Threads: 3
Likes Received: 1 in 1 posts
0 Hi, I keep reading that the ELRS protocol allows for significantly higher range compared to FrSky.
However, I don't understand how one protocol can enable a much higher range than another.
Do more data get lost along the way with the FrSky protocol than with ELRS, or is it because ELRS typically transmits at higher power?
Threads: 73
Likes Received: 345 in 259 posts
Likes Given: 157
19 It uses a more modern system (LoRa) AND can run at a faster update rate.
I fly from a club field that has a history of radio drop outs, bad with Spektrum, and still present with FrSky. We fly legally to UK law so no long range. Since converting my FrSky X12S to ELRS with a Namimno Flash 2.4GHz module I have had NO incidents, while others around me continue to have drop-outs. Nuff Said?
Threads: 122
Likes Received: 853 in 695 posts
Likes Given: 134
20 16-Jun-2023, 06:41 PM (This post was last modified: 16-Jun-2023, 06:43 PM by Rob Axel.) Frsky also created a lot of “issues” when they updated their protocol, it wasn’t “back compatible”, no more support of d8.. and in order to update older (rxsr/xm+) RXs .. you had to hard wire them to the controller.. then re install in the quad.. if u didn’t update ur controller and ordered a new rx.. obtains what version was on the rx wasn’t the easiest… it was a soup sandwich to say the least…
I’m phasing out all my d8/Frsky RXs.. going to crossfire..
It’s not just range, it’s penetration.. and less chance of failsafe.
Just my personal experience ..
Threads: 122
Likes Given: 134
20 That’s the fist time I heard WHY Frsky did what they did .. makes perfect sense. Honesty, when all that hit the market, I was having failsafe issues 50 feet in front of me, either rx failure or from damage.. either way I wasn’t gonna buy another Frsky rx so I got the crossfire module for my taranis.. and didn’t look back.. unfortunately all my 1s builds have built in d8
Threads: 80
Likes Received: 1,420 in 1,066 posts
Likes Given: 843
43 I wouldn't worry about it for smaller stuff. I still fly D8's. None of my gear is LBT. I still fly it.
Try Not, Do or Do Not
- Yoda
