thanks pht2t and voodoo
pod on the stack worked pretty well for me, i usually fly over fields, allready had luck or its rigid enough. bend the screws back in a hard crash, tighten them again.... i should use metal-nuts at least on the bottomplate, but it wasnt enough important allready
hopefully the luck will stay with mee xD
i didnt focus about, but the parts i drilled away gave a twig stylish design. the frame is „broken“ on one arm, any more heavy settup would be a dealbreaker, its rigid and stiff enough for a bump, not a true crash. as i plan to fly the hq4025 on a few settups, i need a propre frames. i own a lot 20x20 electronics, i wont jump on to the 25x25mm aio hype. the betafpv twig mutant 4inch seems a good choice, im researching the true frameweight with canopy... not sure if the 21g i found is the full weight. ph2t do you probably know?
the cam is in a „high“ position, not perfect about the movement, more centered and in the front would be better for the fpv view. we compared differend cam positions on 5inch racetrack, cam position of a tbs source two or a floss frame gave the best view. choice between weight in center or view.
i like to build a 4inch with a hglrc 20x20mm aio fc-4in1 15a, it should/will give a more centered cam position and better view.
pht2 your question was about this?
the pink is what the particular filament of my fpv buddy is, hadnt realy a choice. i could wish another color but im lucky he print for me in hours and he dont like to get money for his nice work. its his most rigid filament, its going to end... there will come another color.
its very nice color to find the quad in grass, in practice its very nice.
sunnday it will be sunny again inhere, fpv maiden will happen :-)
