Threads: 1
Likes Received: 0 in 0 posts
0 Here is my FC that link doesn't work.
Threads: 38
Likes Given: 430
118 I do not have that FC and so I am going to make assumptions here unless you can provide me a copy of your old and new full CLI dump.
This can happen if the new firmware target assigns the uart to a different resource.
If you have the dumps can you compare the resource section to see if there is a difference in the pins mapping?
Threads: 50
Likes Received: 833 in 505 posts
Likes Given: 372
51 It looks like the Tyro79 has gone through at least 2 different iterations of the flight controller. Most seem to be based on the MATEKF411, but I found one post saying that it used a VGOODRCF4 target with remapped motors.
I realise it's probably not very helpful to ask this now, but did you take a CLI dump before you flashed it? Also did you definitely choose to 'apply custom defaults' after you flashed the board?
The ground is for dead people.
Threads: 1
0 I figured that also kafie1980....I just wasn't sure that uarts could be remapped....It works now I was just thrown off by this ..took me forever to figure out what had happened. Thx for the response.
Threads: 1
0 Now I'm having a problem where my fpv video will cut out for a a second and sometimes it comes right back, but if the video loss persists for more then about two seconds my drone just drops out of the sky. It doesn't loose full power( I don't hear the esc's beep) but the drone won't re-arm unless I power cycle it. I'm sooooo lost any input would help.
Threads: 38
Likes Given: 430
118 I would check the VTX antenna and wiring for any loose connections. Also check voltages at the VTX pads to ensure you are getting the correct voltage.
