25-Dec-2020, 03:06 AM
Hi, so I recently just bought a Joshua Bardwell xilo copter after building a few and wanted to get a big one and try it out. Anyway all day I've been trying to connect my tx16s to the r-xsr rx and cannot for the love of my life get them to talk to each other. I have gone through and made sure that they binded to each other and then went ahead to check inputs... nothing. So I went into diagnostic mode and started to check all the uarts, protocols and make sure everything was right in the world in betaflight. Still, nothing, a bit frustrated but not giving up I started to browse forums and find if other people have had the problem. Ive found similar but nothing has worked, I've gone from flashing the fc, the rx, and the tx to actually replacing the old rx since I had another on hand to eliminate that. Still nothing. I cant get the tx to show any movement in betaflight. I know the controller stick movements are good by a. I have a screen showing it, and b. because I've used it in simulators multiple times. I still cannot get it so if anyone could help that would be awesome.
Im putting the dump right here if you need anything else please let me know and ill get it to you as fast as possible
