29-Dec-2021, 04:56 AM
I've had this Tinyhawk II (not freestyle) and the batteries since May 2021. The batteries are RDQ 450Mah 80C 1S.
The batteries appear to charge normally and hold their charge. They will read between 4.1 - 4.2V when I arm and then as soon as I'm airborne the batts drop down to 3.5V and within 20 seconds I'm getting readings from 3.2 - 3.4. It also feels like I'm having to push the throttle much more to get the thing in the air. Then as soon as I land the battery bounces way back up to 3.9v - 4.1V. All 12 of my batteries do essentially the same thing.
I've checked the motors and props for anything entangled and it's clear.
Also... one of the motors frequently sputters upon arming, but then seems to run normally with the throttle up.
Since I purchased all the batteries at the same time I suppose it's possible they could all be going at the same time, but I also have a TH2 Freestyle and I use the same batteries and am not getting the dramatically reduced flight times on that (but that's also using 2 cells.)
I don't want to keep torturing my batteries if it's the quad?
I suppose I could get some new batts and see if that solves my problem, but thought I'd ask here and see if anyone had any advice. : )
Thanks in advance for your knowledge and help!
Sam
Sam
