TINY GATES "ASSEMBLE AND FLY"
I discovered TINY GATES assemble at Drone FPV RacerA French shop specialized in equipment for the FPV racing. I needed a solution quickly climb that I can use during the flight session indoors. It also had to be changed when needed and especially customizable.
Presentation
The kit arrives boxed 40 cm by 30 cm by 25 cm tall.
There are 10 layers of 9 elements in frigolite.
In total we have:
  • 20 angles
  • 30 small pieces
  • 40 large pieces
Mounting
It is possible to achieve with the pictures of the site
5 tiny identical gates
Or indulge in other forms
The internal dimensions are quite accurate for the tiny and other microphones.
You can customize its Tiny gates. By painting or adding accessories like LED for example.
Video
Indoor
Outdoors
Conclusion
LEGO fans and other structures will rejoice. The only limit is your imagination.
At solidity, they have collected a lot during testing.
In use, by cons, disassembling and going back, I have already managed to break some tips.
The TINY GATES "ASSEMBLE AND FLY" dronefpvracer are available at the price of € 29.99 or just under € 6 the gate.
The linkhttps://www.drone-fpv-racer.com/tiny-gates-assemble-and-fly-1344.html
Good flights!
https://pimousse.be/ Belgian FPV & Aeromodelism
I think vusion tiny gates are better
(29-Mar-2017, 08:20 AM)Ahmad Ilyas Wrote: I think vusion tiny gates are better
Not really the same budget/size Huh
Cool stuff! Thanks for sharing
The Obsession IS Real!
  • Pimousse
  Mike Rowe flying tiny whoops!? Rob Axel 1 223 08-Mar-2024, 11:48 PM
  Fly Tribe Magazine Rob Axel 3 835 26-May-2023, 06:41 PM
  Your top3 favourite quads ... if they were the only thing you could fly romangpro 9 996 22-Aug-2021, 03:52 PM
  Accessory NameLessRC Tiny GPS - 1.6g V-22 28 3,626 26-May-2021, 10:53 PM
Last Post: iFly4rotors
  no chance for covid; fly fpv :-) hugnosed_bat 4 624 15-Nov-2020, 11:36 PM
Last Post: EVILsteve
