well it was bound to happen i bricked all 4 racerstar esc's
i 'disconnected' before removing the battery
<thought that bug was fixed , at least there was no blue smoke>
and i got all the errors when re flashing-- including flash file too big .
there isn't a pin out that i could find to go arduino on it ....
plus 2 of the pads have stuff soldered to them so its a very hard deal
to make connections without un-soldering important stuff
so i figured they were toast after about 12 try's, even using BLHS expert mode's
erase or flash any file, it was no way jose.
so i opened all them with the Atmel BL for CF, then open them with the correct
Silabs BL for CF ,went to expert tab and flashed with the 'flash any file'
button
<i guess the Atmel BL opened the esc to read/write and doesn't close the file?>
and BOOM the deed was done
![Popcorn Popcorn](https://intofpv.com/images/smilies/custom/popcorn.gif)
all 4 flashed first try.
So if you'd be so kind , please somebody give it a try and see if it works for you on your
bricked esc.
![Thinking Thinking](https://intofpv.com/images/smilies/custom/thinking.png)
button
![Thumbs Up Thumbs Up](https://intofpv.com/images/smilies/custom/thumbs-up.png)
bricked esc.
