Threads: 11
Likes Received: 4 in 2 posts
Likes Given: 2
0 Hello,
I'm building a racing drone and I connected the TBS unified pro 32 (it works well in one channel only). As soon as I connect the Smart audio wire it stops showing the image and I can't change the channel from betaflight. In betaflight it shows device ready 'Yes'. I have tried different vtx tables SA (1.0, 2.0, 2.1) and I also connected it to crossfire to change the channel from the radio but that did not work either. It just remains frozen to the same channel and I lose the video feed. I only get it back when I remove the SA wire.
Any suggestion would be much appreciated.
Thanks,
Thomas.
Threads: 38
Likes Given: 430
118 Give me the exact link to the Unify vtx you have so I can be sure which model/version you have.
Give me a snap shot of your VTX tables in Betaflight or a full CLI dump.
Threads: 11
Likes Given: 2
0 Hello,
I'm not sure if it's in pitmode but I can't find it in my modes. It is open as I have solid blue and orange light. Could this have something to do with the soft serial? Should I do something there?
Thanks,
Thomas.
Threads: 38
Likes Given: 430
118 SA should work over softserial but the question is what have you softserial’d? Try a normal uart.
Surprised you don’t have pitmode in the modes tab unless you have hidden unused modes with the toggle on the top of that page.
Threads: 11
Likes Given: 2
0 Thank you for your advice. I appreciate you taking the time to help me troubleshoot. I have tried a different UART but still nothing. I will keep on trying to solve this issue. If you think of anything else let me know.
Threads: 11
Likes Given: 2
0 I have already tried both ways but nothing worked. On betaflight it says device ready Yes so in theory it should work but it doesn't. From the radio nothing changes either when I connect it to channel 4 on CRSF. When I remove the wire from both FC and CRSF I have constant reception from channel L3. If I connect the wire to either I lose reception.
Thanks again
Threads: 38
Likes Given: 430
118 Did you try SA on Ch4 of the Crossfire?
I am still not sure if the VTX is unlocked as you never confirmed this.
Can you make a note of all the leds and count their flashes on startup so we can know what the setup is currently?
Threads: 11
Likes Given: 2
0 I tried to attach a video but I can't. Two of the lamps blue and orange are steady. Is not enough proof that it is unlocked.?
Threads: 172
Likes Given: 4,733
100 its unlocked than.
do you remember the configuration where "device ready" was displayed? that would be a matching option. its the best indicator to check smartaudio comunication over betaflight.
you wired the sa cable from the vtx to the tx pad on the crossfire in the picture above? these tx would be for receiver data, rx and tx to connect to the fc. it takes one uart. if you wire the sa to a tx pad flightcontroller to another free uart, you can enable smartaudio on that particular uart. as example uart 4 seems empty actual on your picture above.
i would suggest to disable "lowpower until disarm" for now.
did you checked smartaudio comunication directly by the osd, battery pluged in without connection to betaflight configurator?
Threads: 11
Likes Given: 2
0 Right now it's connected from vtx to tx on the FC. I enabled the sa to that configuration and device ready says 'yes'. Shouldn't it work? Should I go back to CRSF? When I connect sa in either CRSF or FC I don't have an image to allow me to check from osd.
