TBS Tango 2 not binding with TBS crossfire 8ch
I'm working on making a TBS caipirinha 2 using a wing layer. This is my first long-range plane build so there's probably something I'm doing very wrong but in any case, I can't get my Tango 2 to bind with the 8ch tbs crossfire I'm trying to use with it. I've updated the Tango 2 to the latest firmware, but I still can't get them to bind. If anyone has any ideas on what I might be doing wrong that would be great.
Did you try the Emergency firmware procedure:
(16-Jan-2022, 03:40 AM)SnowLeopardFPV Wrote: Try the emergency recovery procedure below, then update the firmware to V6.13 on both your Crossfire TX and RX using TBS Agent M (HERE).
  1. Hold the “bind” button
  2. Power up the receiver
    The led starts to flash rapidly
  3. Release the button
    for about 1-2 seconds
  4. Push and hold the button again
    The green led starts to flash in a double-pattern. When it starts to flash rapidly again, you can release the button
  5. Wait till the update is finished
    When the receiver finished the update it will flash slowly
  6. Now the receiver is ready to bind
    You should power-cycle the receiver to avoid issues
Thanks! I'll try that.
  Binding reciever g-rx8 Smokie 0 519 12-Mar-2021, 05:56 PM
Last Post: Smokie
