T-Motor F80 1900KV + 7 Inch Biblades + 4S?
I'm wondering what I can expect using F80 1900KV motors with 7 inch biblades powered off 4S for my long range build?  These are 2408 motors.  I'm wondering how they might perform compared to BH Avenger 2507 1500KV.  I thought I'd read that height and diameter are not equal.  In this case my +1 height is more power gained than the -1 diameter power lost.
My thought is less efficient getting to cruising speed but at cruising speed more efficient.  Or pretty much the same performance?
You will be fine.  Either one will work, but the bigger BH would probably be better.  Although, I believe T-motor are superior motors, that's good for something, right? Big Grin
I doubt you will try for further out than 5 miles, and both should give you that.....Certainly the BH choice will as they have for me.
Remember the most important component for efficiency is your left thumb.
[-] The following 2 users Like Krohsis's post:
  • hugnosed_bat, the.ronin
(19-Sep-2020, 04:01 AM)Krohsis Wrote: Remember the most important component for efficiency is your left thumb.
That ought to be engraved somewhere. Cool thanks for the feedback. I kinda kick myself cos they just dropped the F90 which evidently is geared specifically for long range.
[-] The following 2 users Like the.ronin's post:
  • Krohsis, hugnosed_bat
brotherhobby has a new 2808 motor :-)
[-] The following 2 users Like hugnosed_bat's post:
  • the.ronin, Krohsis
  5" Mid range motor sizing help B4tn 4 399 01-Mar-2024, 12:25 AM
Last Post: B4tn
  Build Six inch mid range build: MR6 Mike C 51 4,322 06-Nov-2023, 01:41 PM
Last Post: Mike C
  Build 4 inch micro longrange build fpvapnea 17 1,729 03-Mar-2023, 04:24 PM
Last Post: fpvapnea
Question Build 7 inch cinematic long range setup BrianE. 24 5,144 08-Aug-2022, 11:49 AM
Last Post: iFly4rotors
  Motor size blackhole durachoke 5 1,268 16-Jan-2022, 03:52 AM
Last Post: BigBeard
