Stack flexibility too stiff?
On a 7" build, I'm using the m3x30 screws that came with the frame + small aluminum spacers to keep the PDB off the frame and the rubber "gummies" that came with my FC. the stack seems to be moving barely at all and certainly a lot less than all of my other freestyle builds.
Given the reputation larger quads have for being "sensitive" to vibration, is that going to be an issue?
I would be happy with that much dampening. I would not lose sleep over it.
[-] The following 1 user Likes kafie1980's post:
  • cablefpv
  Hard to find pieces to fit Mamba F722 Mini Stack 40A phelipems 5 194 31-Mar-2024, 04:08 PM
Last Post: phelipems
  Mamba F405 MK2 Stack ITGeekLondon 4 3,083 17-Mar-2024, 10:42 PM
  SpeedyBee F405 V3 stack ESC tone issue Rudemagician 3 1,014 17-Nov-2023, 01:09 PM
Last Post: Rudemagician
  SOLVED: SpeedyBee F405 V3 Stack - No BiDirectional Dshot NewFPVPilot 8 3,856 24-Sep-2023, 07:56 PM
Last Post: Mike C
  Axisflying Argus PRO Plug & Play Stack SkullerX 6 970 18-Apr-2023, 08:04 AM
Last Post: voodoo614
