Threads: 105
Likes Received: 54 in 41 posts
Likes Given: 33
0 26-Feb-2022, 12:47 PM (This post was last modified: 23-Apr-2023, 06:29 AM by sim_tcr.) Hello,
I just got new toolkit m7 charger and trying to charge 1s lipo with it.
I set cell count to 1 and trying to charge.
As soon as I start I get error, “Balance port cells match error”
Any idea how to charge 1s using this?
Thanks.
Threads: 593
Likes Received: 9,029 in 6,683 posts
Likes Given: 1,428
795 I don't have a Toolkit M7 charger but on my charger you need to select the standard LiPo "Charge" option (not balance charge) to charge 1S LiPos. That is because there are no cells to "balance" so you just charge it as a single cell battery. I'm not sire if the M7 charger requires you to do the same or not, or if you have separate "Charge" and "Balance Charge" options but just a pointer for you to have a look into. If that doesn't help then if there is a firmware update available for the charger then make sire yours is on the latest firmware version.
Threads: 38
Likes Given: 430
118 I charge LIHV batteries as regular LIPO batteries. They last longer this way.
Threads: 105
Likes Given: 33
0 I took v2.01 update and now I can charge 1s lipo.
Threads: 0
Likes Received: 1 in 1 posts
0 Resetting to default settings really helped. Thank you))
The following 1 user Likes Iho's post:1 user Likes Iho's post • sim_tcr
