Threads: 20
Likes Received: 8 in 8 posts
Likes Given: 77
0 23-Feb-2021, 10:08 AM (This post was last modified: 23-Feb-2021, 10:10 AM by Titanv11.) Just curious as to what item of equipment will more efficiently work, I understand that they will all work but which is better...
1. Auto bulb
2. Electronic Smoke Stopper (online sales)
3. Bench power Supply with adjustable voltage & current.
I have made and/or purchased all three..
What is safer?
I HATE FRSKY!!!
Threads: 50
Likes Received: 833 in 505 posts
Likes Given: 372
51 In order:
- Bench supply (as long as you've set your limits sensibly!)
- Bulb
- Solid state
There's been a lot of reports of those solid state ones not tripping quickly enough to save your components. The exception seems to be the Vifly Short Saver, which gets a lot of good write-ups.
The ground is for dead people.
Threads: 20
Likes Given: 77
0 Ok, thanx.
The solid state is a no name brand so I'll get rid of it...
Do you know what settings to use for a P.S.?
I HATE FRSKY!!!
Threads: 50
Likes Given: 372
51 (23-Feb-2021, 02:24 PM)Titanv11 Wrote: Ok, thanx.
Do you have current sensing on your quad? If so I'd plug a battery in (props off, of course!), make a note of the current draw, add a little bit and use that as your max.
For reference, my 4S quad draws 0.4A with motors stopped (so, FC, ESCs, RX, cam and VTX).
Threads: 50
Likes Given: 372
51 (24-Feb-2021, 05:35 AM)Titanv11 Wrote: So in your case it would be set for 0.5A ??
Maybe start at 0.6A and bump it up a bit if things are getting starved. You'll have to go a bit higher to test motors.
You've got me wondering if I should get one myself, now ;-)
Threads: 20
Likes Given: 77
0 Ok thanx... I get it now.
This hobby makes me feel like I've got an IQ of 10... ;(
I HATE FRSKY!!!
Threads: 50
Likes Given: 372
51 Don't beat yourself up! This hobby has more of a learning cliff than a learning curve.
