After a LONG time away from my workbench / soldering iron, I decided to jump back in with both feet. I was rebuilding my Tinyhawk Freakstyle, and adding my long awaited HDZero / Shark Byte upgrade. This VTX was one of the first SB/HDZ released. Well as I am dry fitting things, I realized this did NOT come with an antenna. I decided to use a Rush "cherry" that i pulled from a older rig. I had read about the U.Fl connectors lifting from the VTX board, but it didnt cross my mind until I decided to reposition the antenna and felt not the "pop" from the connector releasing, but a "tear".... I was like "NO WAY ..realy!" yup.. Luckily, it only partially lifted...So I fired up the hot air station, flux, solder, heat..the U.fl connecter "reseated"...checked for ground and continuity, all good. Back to dry fitting things...this time the UFL came off completely , and separated leaving parts in my antenna UFl. I could see non-ground trace looked like it came directly from a adjoining capacitor / component. I confirmed this with another VTX, so I decided to try and direct solder an antenna. I decided on a linear one I had lying around..figured what do I have to loose..
Added a 2s lipo, no smoke, then added a camera and fired up the goggles... got video... havnt checked signal range / strength yet... Im thinking of maybe doing a MMCX pigtil directly soldered, RMAs are just a little to much weight for this rig.... maybe if i put it in a larger rig.... but for now the "repair" seems to be good...
I know the first gen of anything is not the greatest, I HOPE HDzero has improved the QC of the newer VTXs.
Since I have another one of these VTXs, I may make a U.FL to MMCX pigtail so I wont have to worry about ripping that one off, I can just disconnect the antennas at the MMCX. I know there is some signal loss, but its better than NOT having any signal.
