29-Jul-2019, 05:35 PM
Came in way too hot off a split S over a tree and flew full tilt into the trunk popping the ESC connector housing right off! This was on a Mamba F4 mini stack. I think it pulled the pads since it is no longer sending anything to the FC as much as I try to secure the connector housing back on and there are no pads on the other side I can direct solder.
What's your technique for securing these connector housings on PCBs? This kind of connector ...
![[Image: Diatone-MAMBA-F405-Mini-Betaflight-Fligh...pg-q50.jpg]](https://i.ibb.co/bFZ8X0x/Diatone-MAMBA-F405-Mini-Betaflight-Flight-Controller-F25-25-A-2-4-S-DSHOT600-FPV-Racing-Brushless-ESC-jpg-q50.jpg)
I've normally just used hot glue but wanted to check if there was a new meta out there. Like how we used to use liquid electric tape and thats now replaced with conformal coating.
Thanks!
Thanks!
