Threads: 13
Likes Received: 5 in 5 posts
Likes Given: 46
0 I'm looking for a 3D printed antenna holder that can be rotated around the horizontal axis, allowing the antenna to change pitch angle, or an ad-hoc hack to achieve something similar.
Would appreciate any links or ideas
Threads: 59
Likes Received: 593 in 396 posts
Likes Given: 210
42 You could achieve this by using 2 45 degree SMA adapters, and rotating them each to get your desired angle.
I haven't seen an adjustable mount, normally they are at 45 degrees which is close enough.
