Not to make this another TinyHawk 2 thread, but...
I need to understand if there is a way to make sure that I did not fry the power-distribution portion of my All In One board.
In my efforts to continuously learn I was performing a voltage calibration within BetaFlight on the quad when I was asked to check voltage under load. Now, I say "rookie" as I am new to flying, but I am by means no amateur when it comes to electrical testing for the past decades. So with BetaFlight connected, the 1s battery is connect, probes were held in place; I turned to the meter, in doing so I touched the probes together hearing a mild 'pop'. Voltage drops to Zero on both the meter and on BetaFlight.
I disconnect the battery fearing lipo pop battery is cool and holding charge. The lights on the TinyHawk is are still lit while on USB like nothing has happened. I disconnect from USB and plug in the batter again. No tones, no lights, nothing.
Are my fears that I fried the power distribution portion of the board correct (since I can still connect to the FC portion via BetaFlight), or is there a small fuse that I may have blown?
Any assistance would be helpful.
Checks I have done (besides what I have listed above):
-Connected via BetaFlight, accelo and gyro are fine.
-CLI functions: 'status' indicates 0.1V in both battery connect and disconnected state
-BLHeli connects and reads the Setup just fine.
All signs are pointing to the battery connection point of the board. I just do not know where to go from here.
