Replacing Bowden tube for direct drive - Ender 3 Pro
Do I need to re-calibrate anything, or change any settings when switching from Bowden setup to direct drive? I have a new direct drive coming in today, and want to make sure I do everything right.
Please help me build my YouTube FPV channel: RelenTechFPV
It was a while ago, but I believe I had to recalibrate my e-steps.
Also had to adjust my retraction settings on all of my filament presets.
Dangerous operations.
  • relentlesstech
e-steps will need to be recalibrated as the direct drive might have a slight different gear drive ratio compared to your bowden setup.
Retraction is set lower on direct drives compared to bowden, much lower since in a bowden setup the filament may flex and move inside the tube.
You might even need to adjust jerk and acceleration settings since now you have a heavier print head with a direct drive when compared to a bowden setup.
[-] The following 2 users Like kafie1980's post:
  • relentlesstech, Lemonyleprosy
(10-Feb-2023, 12:18 AM)kafie1980 Wrote: e-steps will need to be recalibrated as the direct drive might have a slight different gear drive ratio compared to your bowden setup.
Wot He Said..................
Thanks everyone! I re-calibrated my e-steps, and my first test print came out great! I definitely like the direct feed better than the Bowden tube, I am able to print almost twice as fast as before, but with better results!
[-] The following 1 user Likes relentlesstech's post:
  • Lemonyleprosy
  Help Need help setting up my BLTouch on Ender 3 Pro! relentlesstech 11 228 07-Apr-2024, 10:15 PM
Last Post: skywanderer
  Help Ender 3 Pro bad prints after upgrading motherboard relentlesstech 8 1,472 15-Jan-2023, 07:21 PM
Last Post: relentlesstech
  A noob and an Ender 3 s1 pro sevro 9 2,759 20-Oct-2022, 05:58 PM
Last Post: sevro
  Solved Ender 3v2 not homing to front and left Cdog 4 2,939 23-Apr-2022, 10:52 PM
Last Post: Cdog
  Review Creality Ender 5 Pro Review bffigjam 4 2,306 21-Jun-2021, 07:40 PM
Last Post: EVILsteve
