26-May-2021, 12:52 PM
One of my betafpv 65x motors is broken, it is betafpv 0802 17500KV. What's the best replacement ? It doesn't look I can replace replace with 0802SE 19500KV ...
0802 17500KV:
[*]Weight: 1.83g/pc
[*]Color: Black
[*]Shaft length: 5mm
[*]Shaft diameter: 1mm
[*]Hole distance: 6.6mm
[*]Motor Mount Holes: M1.4
[*]Input Voltage: 1S
[*]Cables: 25mm long, 30AWG cables
[*]Dimensions: 10.5*10.5*13.6mm
[*]Bearings: Brass Bushings
0802 17500KV:
- Height: 10mm
- Weight: about 1.9g
- Shaft: φ1.0mm
- Motor Mount Holes: M1.3 on Dia 6.6mm
- KV (rpm/V): 17500
- Voltage: 7.4V, 2S Lipo battery
- Plug: Micro JST-1.25 3-pins connector
[*]Weight: 1.83g/pc
[*]Color: Black
