30-Sep-2022, 09:06 PM (This post was last modified: 02-Oct-2022, 04:34 PM by OntarioDrone21.)
Yesterday I spent hours trying to get a damaged propeller off an EMAX Tinyhawk 3 (this is a pusher drone). I would have the fingers of one hand camped on the to top to the motor where it attached to the frame and the other set of fingers clamped around the central part of the propeller and pulled while twisting and pulled and pulled,. The propeller did not budge.
I then tried method 2 using a very small phillips screwdriver against the motor shaft poking through the middle of the propeller while pulling the propeller towards the screwdriver. The still propeller did not budge.
The EMAX manual tells me to use my first method and the prop will just pop off. Super easy to do apparently.
By now my fingers were sore and I gave up on both methods. I got my pair of Mini Flush Cutters and cut the propeller off of the motor.
Is there a trick in removing the props from the Tinyhawk that is kept in great secret? Please tell……
