28-May-2021, 04:20 AM
Hi - I'm switching frames from the Lumenier QAV R2 to the Johnny FPV frame. I thought it would be a pretty simple switch- but I did need to shorten the motor wires on the back of the quad and lengthen them on the front. I'm new to soldering- but it seemed to go well enough. Everything seemed connect, yet embarrassing to share photos. I've done some other soldering successfully so I'm confident it's adequate.
In Betaflight everything seems fine and the motors all appear to be working, but when I go to do a test flight something is not right. It's acting like the troops are on backwards. I've checked the direction and all seems fine.
I've only been in BLHeli once and when I attempted to connect I get a blank screen.
So a couple questions-
Do I need to flash the firmware and then do the CLI all over again since the motors were cut and re-installed? What could I be doing wrong in BL Heli for it to be blank?
Thanks for the help!!
