Quad shutters and won't go
Hi, all. I'm fairly new to quads and have taken on the project of resurrecting a broken Eachine Assassin 180 that I bought. In doing this, I have replaced the motors and ESCs as well as added the wiring and brackets to support a non-proprietary battery. If all goes well, I'm planning on finishing up an action camera mount on top.
Once I got everything wired up and secured, I tested inside to make sure everything spun as it should. I immediately found that it shuttered very badly and that the roll and pitch seemed to not be very stable. I then decided that maybe my issue was some sort of ground effect and I should go outside. I did this to find that I couldn't get more than 2 feet off the ground and it still shuttered and floated around. I am not particularly good at acro in LOS, but I this is moving worse than I would expect. Additionally, I found that the motors with black propellers get pretty warm after a short time while the other two are cold. I figured it was PID related until I couldn't get any altitude, although its possible that multiple things are off.
The modifications include:
* Tattu R-Line 1300 mAh 75C lipo
* Favourite FVT LittleBee 20A ESC
* DYS BE1806-2300KV motors
* RAYCorp 4045 3-Blades 4x4.5x3 Propellers
Here is a video of it at full throttle.
Can I get some ideas of things to look at to track the issue down?
  Discussion Who's Got the Heaviest 5" Freestyle Quad? SnowLeopardFPV 9 5,410 26-Jan-2024, 12:18 PM
Last Post: hawk01
  Build Rescue Quad iFly4rotors 177 13,954 09-Nov-2023, 09:57 PM
  Build What motors for 4" power quad? romangpro 30 2,539 21-Sep-2023, 02:26 AM
Last Post: romangpro
  Quad fall of the sky when doing small throttle move Snyfir 11 675 09-Sep-2023, 10:28 PM
  Discussion 3D printed 6" freestyle quad ( WITH STLs! ) SuryaKK 13 774 24-Jul-2023, 09:30 PM
Last Post: Marcelo
