Quad Shaking
Built my first complete build. Hooked up ocusync air unit (sweet!!!!) but can't get this thing to behave. Shaking like crazy. Tried the following:
1. Checked motors direction.
2. Tried different props.
3. Flashed different bheli firmwares.
4. Tried changing ESC protocols. Dshot300, 600, multishot etc.
5. Noted that motors do not spin equally in Betaflight. Motor 2 always lags behind.
6. Flashed firmware for the FC.
7. Tried different receiver - the same result.
8. Reset radio.
9. Calibrated ESCs.
Configuration:
Motors
ESCs
FC
What can i do to make it fly? Please, help.
Btw, it is not the first drone that behaves like that in my house. Am I cursed?
As I said in your other thread, I don't know about all your motors, but it appears the front right motor is spinning in a clockwise direction
I've played your vid over and over, I could swear both front motors are clockwise and both rears counterclockwise. Really hard to be sure though
No, motors and props are good.
I will be damned. What is going on?
Bad gyro on FC maybe? Since in BF it seems fine but when armed it's uneven sound like a FC problem, especially since that's a clone FC with questionable QC. Just taking a guess here. I knoiw it'd be a pain but might want to consider a higher quality FC like this. http://www.readytoflyquads.com/flip-32-f4-omnibus-v3
I'd rather be flying!
My Builds
YouTube
I wish I could help you troubleshooting, but I am not that experienced; however, I just wanted to say that is not a good idea to test motor spin direction with the props on, particularly if the quad is behaving randomly... just saying.
Good luck finding the solution!
Guys, this related to the FC installed in the wrong direction. Case closed.
Thanks
Glad you figured it out. Never even thought of improper board orientation as the quad's reaction is usually much more severe than a little shaking. I've witnessed the Tazmanian Devil Effect and it's scary. Like ssombra said, you're lucky. Things could have gone very bad..........
  • Drone0fPrey
  Need help with quad drifting…. danny 20 1,088 06-Apr-2024, 04:53 PM
Last Post: infrared4ever
  Anyone ever X-Ray a quad? Rob Axel 0 112 18-Mar-2024, 06:54 PM
  Where do I start PID tuning this quad? relentlesstech 15 353 17-Mar-2024, 05:22 PM
  Mid Air Radio Failure on a quad with RTH Pathfinder075 9 190 26-Feb-2024, 10:26 AM
  Can a DJI RC Motion 2 control anything other than a DJI quad? Wellcordinated 8 654 17-Feb-2024, 05:00 PM
Last Post: segler999
