Threads: 30
Likes Received: 45 in 32 posts
Likes Given: 60
1 13-Oct-2020, 12:33 PM (This post was last modified: 20-Nov-2020, 11:37 PM by Pekka.) Tyro129. Put on Gemfan Flash 7042 bi-blades and this happens on throttle up (at the beginning and end of video). Check out the voltage sag as well.
Tried lowering and raising PID sliders but doesn't seem to help. Flies smooth just cruising on low throttle.
Threads: 172
Likes Given: 4,754
103 13-Oct-2020, 02:57 PM (This post was last modified: 13-Oct-2020, 02:59 PM by hugnosed_bat.) it start shaking at which throttle area?
ifbitbisnin midthrottle area, play with tpa breakpoint could probably solve it mostly
Threads: 30
Likes Given: 60
1 16-Oct-2020, 12:05 PM (This post was last modified: 16-Oct-2020, 01:02 PM by Pekka.) It's fixed. Lowered TPA from 1400 to 1100 and scaled throttle to 75%. Thanks!
I think a 7 inch carrying a 3300mah 4s might be too heavy and powerfull for the Gemfan Flash 7042's. They're so flexible that they just can't keep up with the power. But they seem to be good and efficient for cinematic cruising with a scaled down throttle.
Threads: 172
Likes Given: 4,754
103 nice you found a solution with tpa.
probably a second pid profile with lowered pid could provide the ability to settup the tpa up a bit higher, if you like to explore more :-)
