Threads: 2
Likes Received: 0 in 0 posts
Likes Given: 3
0 Hi, I have a question. I'm currently running a Radix F4 analog on a 7" Super G+. I'm going to put a vista in it and trying to figure out if the Brain OSD will work with DJI FPV goggles or if I need a different FC.
Thank you,
Tony
Threads: 50
Likes Received: 832 in 504 posts
Likes Given: 372
51 You'll be fine.
DJI uses a completely different mechanism for OSD (using the MSP data from the flight controller) so the OSD chip on the FC won't be used at all. As long as you've got a spare UART you're good to go. Keep in mind that powering the air unit (or Vista) might be more awkward though, since you can't do it using 5V.
The ground is for dead people.
Threads: 584
Likes Received: 8,957 in 6,628 posts
Likes Given: 1,425
786 No problem. JB's walkthrough video below for configuring LQ in the DJI OSD should help...
