Threads: 10
Likes Received: 20 in 12 posts
Likes Given: 29
1 26-May-2018, 11:14 PM (This post was last modified: 02-Jun-2018, 04:51 PM by JMcGraw47.) CLRacing F4s FC
KingKong 15A ESC
EMAX-MT2204 Motor
It wants to spin up but tends to stutter...Only the M3 one that is.
Connected to BLHeli and checked settings, identical to the other three, ran the beta test etc and no response at all.
Connected to Betaflight (latest version) and same results.
Any suggestions on the best way to isolate if it is the esc or motor? I do have a nice Fluke meter and know how to use but not what to look for.
Threads: 67
Likes Received: 713 in 473 posts
Likes Given: 1,216
23 Put one of the good motors on that ESC.....if problem remains, it's the ESC, if problem goes away, it's the motor.
Threads: 10
Likes Given: 29
1 Just for "Grins" and statistical data purposes I will Ohm a good motor and compare to the potential bad one and Fluke the ESC while energized at various throttle settings.......Must be the Maint man coming out in me from my Refinery days!
Threads: 125
Likes Given: 99
388 My bet is on the motor. Either bad solder to one of the wire lead, broken winding or long screw. You should be able to determine quickly troubleshoot with sirdude suggestion.
Threads: 10
Likes Given: 29
1 Conclusion:
Turned out to be the ESC, here are my Fluke findings.
De-energized and connected to esc each leg of the solder joint measured 0.3 ohms.
Disconnected each leg measured 0.3 ohms, on the esc (disconnected from motor leads) each tab measured 40kilo ohms (typical reading back through a circuit board)
Energized, connected and armed at min RPM of 1150 rpm the voltage read battery voltage regardless of throttle setting. ( ESC must be controlling current)
While measuring esc tabs I pressed down on esc a little and it started working, prior to that the voltage kept fluctuating between 0v and battery voltage.
4 new ESC's on order and 3 spares for foam board projects.....Flite Test videos inspired me...
