Pre-arming (two stage arming)
I would like to start using two-step arming as a safety measure.  However, as I look at the modes in Betaflight I cannot see a mode for pre-arming with my Emax Freestyle 2.  Is there a way to add this pre-arming to every quad, even if it is not shown in Betaflight?  Thanks in advance.
Make sure the "Hide unused modes" switch at the top left on the Modes tab is switched on. Then you should see a "PREARM" mode that you can configure.
  • Sphere
Bardwell did a great video on how to program pre-arming in OpenTX which means you don't need to use up another channel. I highly recommend looking into that rather than using Betaflight prearm.
Unfortunately, my radio does not use OpenTX so I am stuck using up a channel with Betaflight prearm.
[-] The following 1 user Likes the.ronin's post:
  • Sphere
I'm probably one of the few people that use pre-arming. For me it is a simple matter of safety and a deep rooted respect for what spinning propellers can do to you. Had a friend many, many years ago that stuck his hand through 12x6 prop on a 4-stroke motor that was idling. He lost a LOT of blood on the way to the hospital. Not a pretty sight.
For me, in the modes section of BF I set Aux switch 1 to Pre-Arm in the middle position and then Arm with Aux switch 2 in the third position. I chose using the middle switch position for pre-arm because it isn't a position I can easily bump the switch into. I have to deliberately move it to the middle.
There is a safety switch we used to use on FM RF modules back before 2.4 ghz came out.
We had to pull switch up and then flip up or down.
Basically impossible to bump and switch.
It would work as a pre arm switch.
We used them so we didn’t switch radio channels and knock ourselves and another’s radio out during flight.
https://www.mouser.com/images/nkkswitche...FI_SPL.jpg
  Cannot clear CALIB arming flag in betaflight necbot 16 384 26-Jun-2024, 06:04 PM
Last Post: necbot
Photo Crux35 not arming Cumulus 4 184 09-Jun-2024, 09:29 PM
Last Post: mstc
  Very inconsistent motors/ARMING tenaciousFPV 7 352 15-May-2024, 04:11 AM
Last Post: husafreak
  Solved Pre-mature Low Battery warnings in my Avatar OSD Seii-FPV 45 2,169 03-Jan-2024, 04:11 AM
Last Post: Seii-FPV
  Air UNit O3 Shut down while arming janpme 1 192 06-Dec-2023, 09:37 PM
Last Post: voodoo614
